While driving down the road, engine just died. Turns over fine, just no spark. Should be something simple,
some relay. Can you give me a suggestion?
Tuesday, October 28th, 2008 AT 2:39 PM
MECHANIC
Best check that the cam belt has not failed, check power into the coil, if there is power at the coil have the distributor checked also run a scan for any set fault codes.
