1992 Honda Accord Unstable Idle
SANTO_V24
I have a 1992 Honda Accord with 180,000 and a 2.2 engine and i have been trying to figure out why my cars been shaking so much and cant keep the same idle speed sometimes it will go so low it wants to turn off or it does. i have changed the spark plugs the wires the disrubutor cap and rotor and i have no idea what else it could be.
Feb 6, 2007 at 4:45 AM
BRUCE HUNT
  • 3,754 POSTS
If the car seems to be surging please start with checking the coolant for proper level and with it running open a bleeder on the upper radiator hose to release air in the system. After that check for any vacuum line leaks. Let me know.
Feb 6, 2007 at 11:09 PM
Suggested Repair
Check the coolant level and, with the engine running, open the bleeder on the upper radiator hose to release trapped air. Then inspect the vacuum lines for leaks.
Conversation Summary
The owner of a 1992 Honda Accord with a 2.2 engine reports shaking and an unstable idle that sometimes drops low enough to stall. Spark plugs, wires, distributor cap, and rotor were already replaced. The expert recommends checking the coolant level, bleeding air from the upper radiator hose, and inspecting for vacuum line leaks.
