1992 Honda Accord
1992 HONDA ACCORD
298,000 MILES • 4 CYL • 2WD • MANUAL
TCHAYNES
please help my car starts screaming when i turn it on near the power sterring motor than after that my odometer and speed odometer stop working than my car wont move if i leave in nuetral and push the gas it sounds like my transmision is coughing
Aug 27, 2009 at 11:14 AM
  • 31,937 POSTS
Hi there,
Check that the power steering belt is tight and if so check that the pump is actually turning, as for the transmission, check that the oil level is correct and that the oil is clean and not smelling burnt, if in doubt and problems still exist contact a transmission specialist as this will require first hand inspection to locate the problem..
mark (mhpautos)
Aug 27, 2009 at 11:24 AM
