1991 Honda Accord Sports Mode
1991 HONDA ACCORD
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
AWSTOECKL
The setting of the shift leaver can be 1,2,3 and D. On the leaver is a botton for Sport. In on postion a S light is on on the dash board.
PROBLEM:
The on - off position of the sport mode does not work anymore. The light is on at all times. Shifting from 1 to 2 works. Shifting from 2 to 3 and D does not accelerate anything. In 3 or D position, the transmission does not speed up automatically at any engine rpm. It takes about 2600 rpm to speed up to 40 miles while stuck in 2nd gear.
I took the cover around the transmission leaver out and the 2 nuts which holds the contacts to the sliding leaver. I cleaned it with an electric spray to ensure better contacts - no change.
I had next to no problem in all these years with my Honda car. I would appreciate if you could give some advice.
Thank you very much.
Tony Stoeckl
Feb 20, 2008 at 12:02 PM
H4HIR
Hay Tony..
I got the perfect solution, u can refer following link. I also had same problem with my 1990 honda accord.This guy repaired for me and i drove after almost 11000 miles my car,and still i don't have problem. He is really genius person to fixed your problem.You can refer my name my name is "Harry".here is the link for the email address of that person and detail and phone no.
Mar 23, 2008 at 6:22 PM
DAVID1517
I call this guy name " Hiren Patel". He talked very niced and feel like technically sound knowledgible peson. Last month i sent my TCM/computer and he fixed perfectly and returned it in same week. my car is running like CHARm and like brand new...
Jul 13, 2010 at 10:08 PM
