Hi Mrtlockett,
The fluid has leaked dry, you need to check where the leakage is from. Pedal is spring loaded to push down after it has travelled more than a certain travel of the stroke and you need to lift it up if there is no pressure from the master cylinder.
Saturday, July 19th, 2008 AT 2:26 PM
