I took it to my mechanic, and they replaced a part that attaches to the alternator which was producing low spark. This has not solved the problem.
I've seen a few discussions where it this can be linked to one of the following problems:
1.) Leaky fuel injectors
2.) Main Relay
3.) Need extra air in the cylinders (so hold the pedal halfway down when starting)
4.) Starter is heat soaked (causing to much internal mechanical resistance)
5.) Ecm needs to be changed
6.) Ignition switch
Do you have any suggestions?
Sunday, June 29th, 2008 AT 2:40 PM
