Will not crank sometimes
150,000 MILES • 2.3L • 4 CYL • FWD • MANUAL
DILL-11
  • 126 POSTS
My car has a new starter and battery, but some times when I turn the key I get nothing no start no lights. Some one said it may be something call a starter cut relay. What do you think it is? Please help? Also, will not turn over.
May 2, 2017 at 11:13 AM
CARADIODOC
  • 34,414 POSTS
When additional lights and circuits are involved, that is more than just a starter circuit problem. You have to look at what they all have in common, and one of those things we see real often is a bad connection at the under-hood fuse box. Follow the smaller battery positive wire to that connection, and be sure that is clean and tight. While you are at it, follow the smaller battery negative wire to the body and be sure that one is tight and not rusty.
May 2, 2017 at 11:22 AM
