The distributor had the ignition coil in it, right? And that was replaced or did you reuse the coil? That distributor I believe also has the camshaft position sensor and that was on the distributor as well. New or used distributor?
When the vehicle shuts down, that is when you need to be testing the vehicle for spark and fuel to the cylinders. One of those is failing and causing the car to quit. Once it quits, pull a plug wire and check for a spark. Pull a plug and check if it is wet with gas.
We might be headed to the crankshaft sensor. Let us know what you find.
Saturday, April 19th, 2008 AT 11:00 PM
