Loud squeal; car dies while driving
244,000 MILES • 4 CYL • 2WD • AUTOMATIC
MDH4
Hi there!
Yesterday I was driving approximately 50-60km/h when all of a sudden the check engine light appeared and the interior dash lights started to dim and then the car lost power and came to a full stop - al within about 15seconds. I tried to start the car again and nothing, it wouldn't even turn over. For the last few weeks - everytime i start my car there is a very loud squeaking noise coming from the engine area (perhaps a belt). the sound usually continues for a few minutes, and then stops completely. This is the first time the car has completely lost power like this. Could this be my alternator, battery, or maybe even main relay (i had it re-soldered a year ago and was told it could go at anytime)? I checked the belt and it seems tight.
Thanks!
Jan 10, 2014 at 4:32 AM
SATURNTECH9
  • 30,869 POSTS
The first thing you should do is have your battery charged and tested also pop your alternator belt loose and see if the alternator siezed up?Do you have a multi meter to do some testing?
Jan 10, 2014 at 6:54 AM
MDH4
Unfortunately i don't have a meter. Any other suggestions? How can i tell if the alternator seized up?
Jan 10, 2014 at 7:02 AM
SATURNTECH9
  • 30,869 POSTS
I just mentioned that pop the belt off the alternator pulley and see if the alternator pulley will turn freely by hand.
Jan 10, 2014 at 7:50 AM
HONDATECH1983
  • 109 POSTS
It you're dash lights went out you could have a bad ignition switch.
Jan 16, 2014 at 10:42 AM
