Are there any codes?
Try cleaning the iac motor.
Remove the IAC valve and block the ports to the intake. The engine should then run at a low steady idle.
Make sure the coolant is full.
Check the fast idle valve ( left side of the intake), you need to remove the cover (2 screws) There should be no air passing through when hot. You can adjust the plunger
with a wide flat screw driver to close it. If you're still
not sure you can remove it from the plenum and cover the two holes and see if the idle returns to normal.
SPONSORED LINKS
Tuesday, June 10th, 2008 AT 7:27 AM
