1990 Honda Accord
JASEN789
  • 1990 HONDA ACCORD
Transmission problem
1990 Honda Accord 4 cyl Front Wheel Drive Manual
having problem with how the clutch peddle spring go on it the book does not tell me or has pic with how the part goes on it
Sunday, September 12th, 2010 AT 7:55 PM
KHLOW2008
  • 41,814 POSTS
Hi jasen789,
This is the only diagram I can find in our database. Hope the outline of the spring is sufficient to get you going.
If the spring is correctly installed, when master cylinder push rod is not attached or there is no hydraulic pressure, the pedal should spring downwards when depressed and you need to manually lift it up. At a certain height it would spring back up.
https://www.2carpros.com/forum/automotive_pictures/192750_ClutchPedal90AccordFig01_1.jpg
Wednesday, September 15th, 2010 AT 2:00 PM
