1989 Honda Accord just died while driving!
GLEN1967Q
  • 1989 HONDA ACCORD
  • 4 CYL
  • FWD
  • 120,000 MILES
Replaced coil, tested moduel, TDC ok still no spark! Tune up(plugs, wires, rotor, cap done in past 6 or so months
only thing left that I did not check in "Haynes manual" is the so-called Radio condenser. Is that little thing the possible cause?
ps-i cant find that part anywhere
Sunday, September 5th, 2010 AT 5:22 PM
  • 109,959 POSTS
Have you checked if the coil is getting power? Also, have you checked the crank sensor? Timing belt?
Monday, September 6th, 2010 AT 1:13 AM
GLEN1967Q
Coil is getting power, timing ok. Does a 2.0 carburated honda have a cam sensor? Cant find it in any book or parts inventory
Sunday, September 26th, 2010 AT 4:50 PM
  • 109,959 POSTS
No, it doesn't have one. Are you getting any spark out of the coil?
Monday, September 27th, 2010 AT 10:25 PM
MOTOKING_1990
  • 10 POSTS
Open the oil fill cap and look inside to see if the cams or rockers are moving if not it is your timing belt!
Monday, October 4th, 2010 AT 4:01 PM
