when I start my car it turns over, starts but then immediately dies. If I wait and then try again it eventually stays on. And it doesn't happen every time.
Wednesday, December 23rd, 2009 AT 8:02 PM
MECHANIC
Check your fuel pressure if its within specs if okay-check and test the electronic air control valve and throttle angle sensor and coolant temperature sensor. Also run the codes here is how.
