1989 Honda Accord hard start, bad idle, stalls at stops &
HJS
  • 1989 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 20,300 MILES
Purchased 2 mo. Serviced and tested okay then. Tried to run AC (warm but blows). Now even with AC-air-radio off car shudders & stalls everytime at stops, turns, or deceleration. Need to put in neutral and rev up to ease into first. All levels are fine. Would like to know what to ask a repair shop specifically since I want to avoid excess repairs. Also can I repalce freon myself?
Tuesday, April 29th, 2008 AT 9:49 PM
LEGITIMATE007
  • 5,121 POSTS
Is this car have a manual tranny? And yes you can replace the coolant yourself but you will have to retrofit it first.
Wednesday, April 30th, 2008 AT 5:51 AM
LEGITIMATE007
  • 5,121 POSTS
I have to add too, that if you need to fill the a/c system then there is a leak. The system is designed to be sealed, therefore it should never have to be refilled unless there is a leak, leak would have to be fixed first.
Wednesday, April 30th, 2008 AT 5:53 AM
