My key no longer works in the ignition due to wear is there anyway to replace the ignition without it
Saturday, June 21st, 2008 AT 10:20 AM
KHLOW2008
MECHANIC
Hi robmoll,
If the key cylinder is worn, then you have to replace the whole assy. If the ignition switch is faulty, it is a separate unit. Tumblers can be repaired by the locksmith.
