1987 Honda Accord Fuel Pump
HMANELLARI
  • 1987 HONDA ACCORD
Engine Mechanical problem
1987 Honda Accord 4 cyl Front Wheel Drive Automatic
how to remove gas tank
and remove fuel pump?
Sunday, October 4th, 2009 AT 7:23 PM
BMRFIXIT
  • 19,053 POSTS
FUEL PUMP
Removal & Installation
No need for tank removal
Relieve fuel pressure.
Remove fuel pump access cover located inside of luggage area. Disconnect fuel lines and coupler. Remove fuel pump mounting nuts.
Remove fuel pump from fuel tank through access hole. If fuel pump is hard to remove from tank, loosen fuel tank mounting nuts and slightly lower fuel tank. To install, reverse removal procedure
Sunday, October 4th, 2009 AT 8:29 PM
