1998 Holden Commodore Oil Leak
211,000 MILES • 6 CYL • 2WD • AUTOMATIC
PRANAV GAUR
Hi
I by mistake had put too much oil in my car, while topping it up. I continued to drive, untill i got an oil warning light on dash board.This would be 150 Km's.
I called RACV, and got the excess oil drained.
Now, I notice some oil is leaking from the engine, can it be due the same thing.
Would it be cheap to fix ! ? the car otherwise runs perfect.
Jan 5, 2010 at 11:15 AM
  • 31,937 POSTS
Hi there,
You need to get the engine washed down and have this leak identified, it my be a very simple fix, have the leak checked and report what is found here for more advice if required.
mark (mhpautos)
Jan 10, 2010 at 9:57 AM
