1997 Holden Commodore Replacing the radiator
MARKADURRAND
Engine Cooling problem
1997 Holden Commodore 6 cyl Two Wheel Drive Manual
Hi There I was wondering if you could give a list of the basic tools required to replace a car radiator?
And could you give me comprehensive list of tools and equipment needed to replace a car radiator.
Thank You
Feb 11, 2010 at 12:18 PM
  • 31,937 POSTS
Hi there,
3/8" drive socket set, 10mm short extension bar ratchet, screw driver for hose clamps, undo fan plug, undo 4 X 10mm fan shroud bolts, remove hoses, undo 4x10mm radiator mount bolts, lift out radiator.
mark (mhpautos)
Feb 14, 2010 at 7:12 PM
