1993 Holden Commodore
1993 HOLDEN COMMODORE
BUSHY05
compression cylinder test differs frfom cylinder to cylinder what could be the problem
Oct 2, 2009 at 10:35 PM
  • 31,937 POSTS
Hi there,
You will need to do a wet test... this is where a small amount of oil is added to the cylinder just a few squirts from an oil can, this will seal the rings and then do a comp test again, if the comps come up the rings are a problem if not the valves are the problem, do this one cyl at a time, and the rule of thumb is no less the 10% variance from high comp to low comp.
Mark (mhpautos)
Oct 7, 2009 at 10:03 AM
