Check engine light on, high RPMs and code 0507
155,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
MIKEY6945
My engine light keeps going on. I replaced throttle body and tried to relearn it it still comes on.
Jan 31, 2021 at 6:39 AM
  • 110,248 POSTS
The first thing I would recommend is to check for engine vacuum leaks around the throttle body and the intake. Check everywhere, but focus on the areas I mentioned.
Here is a link that shows how to find a leak:
Let me know what you find. Also, let me know if you have access to a scan tool that can read live data. If you find no leaks, I have the diagnostics, but it will require a scanner that can perform certain tests.
Take care and God bless,
Jan 31, 2021 at 11:24 AM
