High or fast Idling
86,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
PCHITOWO
  • 10 POSTS
I recently removed the head of the Vitz engine after it had failed to start. I discovered that it had damaged the valves so I replaced them. I cleaned the throttle body and MAF sensor and re assembled the components that I had removed. The car is now starting but I have a problem with the idling, it is too high what could be the problem? I am not a mechanic but I have some general knowledge of automotive mechanics.
Nov 21, 2018 at 4:28 AM
  • 110,248 POSTS
Since you had everything apart, my first suspect is a vacuum leak. Recheck that all vacuum hoses are attached and not damaged. Also, make sure the air inlet tube from the air filter box is correctly attached. Follow this link to locate a vacuum leak.
Nov 21, 2018 at 8:18 AM
PCHITOWO
  • 10 POSTS
It did help thank you so much for the help. You guys have been so helpful. I checked the vacuum hose and found that it was indeed broken.
Nov 29, 2018 at 3:18 PM
  • 110,248 POSTS
I am glad it helped. Let us know if you have questions in the future.
Take care and have a good weekend.
Nov 30, 2018 at 11:25 AM
