Hesitation with throttle
CWJR
  • 1990 FORD F-150
  • 5.0L
  • V8
  • 4WD
  • 188,000 MILES
I replaced a new timing chain with gears, a fuel pump, the distributor, oil change, spark plugs and wires, idle position sensor, throttle position sensor, and the air charge temperature sensor. Still does not change the fact that when I accelerate the truck to the next gear or from park to drive or reverse the truck wants to slow down and shut off. Shifts through gears fine but when I accelerate from gear to gear it hesitates. I can not seem to find the problem?
Thursday, February 28th, 2019 AT 1:33 AM
  • 52,797 POSTS
Good morning,
Wow, a lot of parts with no results.
https://www.2carpros.com/articles/engine-hesitates
I would start by having the back pressure tested on the cat converters to be sure the exhaust is not restricted.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Also, The injectors may also be the issue. I would have them professionally cleaned. Additives have no effect on cleaning.
Are there any codes set?
Tuesday, April 6th, 2021 AT 12:47 PM
CWJR
No codes. The check engine light isn't even on.
  • 52,797 POSTS
Okay, I would check the two items I listed to be sure they are not the issue.
CWJR
I will. And thank you.
  • 52,797 POSTS
You are welcome.
Always glad to help.
