Hesitation upon acceleration
145,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
MONTANASKYES
Hesitation upon acceleration especially when it goes into overdrive. I changed the fuel pump to fuel filter, tune up air cleaner. Have not changed any sensors and PCM. does it need to be reset after fuel pump change? thank you for your help.
Feb 25, 2019 at 5:43 AM
Good afternoon,
No, the PCM does not need to be reset. There is no reset for the PCM anyway.
https://www.2carpros.com/articles/engine-hesitates
As far as the power, I would start with check the back pressure on the catalytic converters. If they are restricted, it will give you low power.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Apr 6, 2021 at 5:45 AM
