Help !!! ASAP please
198,000 MILES • 4.5L • V8 • RWD • AUTOMATIC
CECI8757
Rough idle engine shakes with white smoke coming from exhaust and smells like a lot of fuel
Feb 3, 2016 at 11:34 AM
CARADIODOC
  • 34,400 POSTS
White smoke from the exhaust is a sign of burning engine coolant due to a leaking cylinder head gasket. Your mechanic can perform a simple chemical test at the radiator to verify that.
Feb 3, 2016 at 11:44 AM
CECI8757
Not loosing coolent, the smoke coming out of the exhaust smells like gas and car waisted a quarter tank of gas in a matter of 5 minutes checked for gas leaks and there is none, but it seems gas is coming out of the exhaust
Feb 3, 2016 at 11:51 AM
CARADIODOC
  • 34,400 POSTS
Excessive fuel usually makes black smoke. To go through gas that fast, probably the best suspect is a leaking fuel pressure regulator, but I don't know if your engine uses one by the engine. If it has one on the fuel rail, remove the rubber vacuum hose going to it and check if it's wet with fuel inside. Replace it if it is. I suppose an injector could be stuck open too but that would not be common, and I don't think it would use fuel that fast.
Feb 3, 2016 at 12:15 PM
