2021 Chevrolet Silverado Rough Idle
110,200 MILES • 2.7L • V6 • TURBO • 2WD • AUTOMATIC
TEMARSHALL89
  • 11 POSTS
I can’t locate the camshaft position sensor B bank 1.
Jan 14, 2025 at 11:26 PM
  • 55,688 POSTS
These engines have a balance shaft drive chain which can break and cause the engine to vibrate, this there any other codes? If not, this is where I would look, Also, if you upload a short video from under the hood of the engine idling, I can tell for sure what's going on.
I would make sure the engine oil is clean and full with a new oil filter. Code P2C17 will come up if the camshaft actuator is not working, which happens when the oil is low or needs to be changed. Also, are there any noise from the engine while idling? Here is the location of the sensor but I am not sure if that will fix it, please let me know, The sensor B bank 1,
The P2C17 code in your 2021 Chevrolet Silverado 2.7L Turbo is related to the Exhaust Gas Temperature (EGT) Sensor, so I am getting conflicting reports on what the code is but the majority is for the Exhaust Gas Temperature (EGT) Sensor Bank 1, Sensor 3. Is if the turbo has fallen apart internally it will cause this code. Did the engine have good power before this problem? Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with.
Jan 15, 2025 at 5:43 AM
TEMARSHALL89
  • 11 POSTS
So the dealer had my truck for 3 weeks and couldn’t figure out the problem. The day I picked my truck up I drove about 160 miles and the issue returned.the dealer said they left something “open” to see it it would fix the problem so when my engine light came on I got 2 different codes than before. When I clear out the codes and wait a second it goes away.
Jan 19, 2025 at 12:47 AM
  • 55,688 POSTS
Okay, it looks like you have two problems.
P0353 the coil and spark plug on cylinder C (3) so I replace the coils and the spark plugs, in fact all the spark plugs should be changed if they have not been already.
P2C13 - Problem is the exhaust camshaft actuator is not working, this can be because the engine oil is low or needs to be changed which I would try first, then clear the codes to see what happens.
Please let me know I am interested. Thanks for the video and images.
Jan 19, 2025 at 2:10 AM
  • 55,688 POSTS
What ever happened with this?
Dec 21, 2025 at 3:11 AM
TEMARSHALL89
  • 11 POSTS
I replaced all camshaft sensors and camshaft magnet…spark plugs and coils…haven’t had the problem since.
Dec 21, 2025 at 6:42 AM
  • 55,688 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Dec 22, 2025 at 2:47 AM
Suggested Repair
Check and change the engine oil and filter first, since low or dirty oil can prevent the exhaust camshaft actuator from working. If codes remain, replace the cylinder 3 coil and all spark plugs, then the camshaft sensors and camshaft magnet. The owner reported the idle and vibration problem stopped after those parts were replaced.
Conversation Summary
A 2021 Chevrolet Silverado had rough idling, heavy vibration, and code P2C17; the owner could not locate camshaft position sensor B on bank 1. The expert discussed possible oil, balance-shaft, actuator, and exhaust-temperature issues and later identified coil/spark-plug and exhaust camshaft actuator codes. After the dealer could not resolve it, the owner replaced all camshaft sensors, the camshaft magnet, spark plugs, and coils, and reported the problem had not returned.
