Truck misses when ambient temp. is below 45 degrees. It runs very rough until engine temp is warm, then runs perfectly. When ambient temp is above 50 upon start-up, there are no problems.
The fuel pump reads 59 to 65 psi, the injectors balance within 1/2 pd of each other, replaced O2 sensors, cleaned throttle intake and bore, installed new plugs and wires, and installed a new 2-wire temp sensor next to the number 1 cylinder. Also installed new fuel filter.
There are no codes from the scanner and all parimeters seem to read within normal range.
What can be done to fix this problem?!
Thanks you for any help you can provide.
James
James
Nov 27, 2007 at 12:07 PM
