heater core removal
125,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JOHNDAUER
car has air conditioning. can the heater core be removed from inside the car?
Aug 15, 2019 at 10:50 AM
  • 110,248 POSTS
Welcome to 2CarPros.
It has been a long time, but if I recall correctly, it is in the vehicle so it has to come out from inside the vehicle regardless if it has AC. You will have to unbolt everything under the hood to actually remove it, but that is how it's done. You will also need to remove the glove box. And there are (I believe) five or six nuts under the hood that secure it to the firewall.
Let me know if that helps.
Aug 15, 2019 at 12:32 PM
