Heater core hose
270,000 MILES • V8 • AUTOMATIC
SHERRY INGLE
My car has been running hot it has a new thermostat and no body can figure out why it is still running hot. so today we drove it and it ran hot, my son looked under the hood and the heater core hose was steaming, so he replaced it. now there's no water flowing in the hoses.
May 16, 2019 at 11:04 AM
  • 110,248 POSTS
Welcome to 2CarPros.
When you say there is no water flowing in the hoses, are you referring to the heater hoses only? Did he bleed the system? Does it overheat if you are driving at highway speed, does it overheat or is it only in stop and go traffic?
I have to be honest, there are many things that can cause an engine to run hot. Things such as a plugged catalytic converter, rich fuel mixture, timing, and many others. I have to assume the people who checked it also inspected the radiator for excessive corrosion, blocked passages in the engine block and so on. Also, this vehicle would have come from the factory with a coolant called Dex-cool. If regular green coolant was mixed with it, that will cause serious cooling system issues.
Also, inspect the water pump for leaks. Here is a link that will help:
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
Let me know what you find.
May 16, 2019 at 12:21 PM
JIS001
  • 3,412 POSTS
Hello and welcome to 2CarPros. I would also like to add a link on overheating.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
But what I have seen also is the cooling system not properly bleed. I would recommend you buy a new radiator cap and watch this video link on bleeding the cooling system. I do it differently but this video is pretty good. Just ignore the fact he is using wrong coolant. Here is the link:
Watch "how to bleed coolant system 3.1/3.4 liter" on YouTube
https://youtu.be/ad9u8jADrvU
Make sure all the air is bleed out the cooling system. Let us know if the information helps.
May 16, 2019 at 5:04 PM
