Heater blows hot for about fifteen to thirty seconds when first turned on and then goes lukewarm to cold
  • 109,896 POSTS
Check this. First, make sure the coolant is full. Next, with the engine running, hot, and the heater on, feel both heater core hoses. Both should be hot. LEt me know what you find.
Friday, February 19th, 2021 AT 7:56 PM (Merged)
WBYNUM
  • 2000 CHEVROLET TAHOE
  • V8
  • 4WD
  • 190,000 MILES
Engine normal operating temperature, heater is not getting very hot.
PEAR69
  • 1,482 POSTS
Flush the cooling system without a thermostat, especially the heater core, then install a new thermostat and coolant. If the heater core will not flush easily, it could be blocked -- in which case a new heater core should be installed.
FREDRICKWILLIAMS
  • 180,000 MILES
Why doe my heater only work in the rear of my vehicle and not the front?
Friday, February 19th, 2021 AT 7:57 PM (Merged)
DRCRANKNWRENCH
  • 3,380 POSTS
The is an air door actuator that has gone bad. this guide can help fix it.
DON JEWELL
  • 5.3L
  • V8
  • 218,000 MILES
No heat in front, great heat in back!
HMAC300
  • 48,601 POSTS
Try pulling HVAC fuse inside truck for sixty seconds with key on it may reset actuator. It would be the blend door actuator if heater hoses are hot when engine warm.
