heater
159,000 MILES
GILES4819
idling it blows cold air running down highway it blows hot.
Mar 7, 2018 at 5:50 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
It sounds like you are having a problem with coolant flow through the heater core. try back flushing out the heater core.
Mar 7, 2018 at 6:12 AM
BOBGILES4819
Thank you for the information, but how do you back flash heater cord?
Mar 7, 2018 at 6:22 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
They sell a T-fitting that a garden hose fits on. The only thing is that you have to cut a heater hose in half. Install the T-fitting, then hook the garden hose up to it, turn on the garden hose full blast, then remove the radiator cap, start the engine and allow the garden hose to force any clog out of the heater core and hopefully out of the radiator cap filler neck. Or you could just replace the heater core. You should still add some flush to the radiator first, let the engine run until the engine is warm and thermostat opens, like thirty minutes or so, to allow all the flush cleaner to circulate throughout the entire cooling system, then drain all the coolant out, and replace with the proper mix of coolant/water, usually 50/50.
This should be done before if you decide to replace the heater core and or even before you try a heater core flush cause the coolant flush chemical will also help loosen up whatever is clogging it.
Maybe watch a couple videos about flushing an engine and/or heater core. https://goo.gl/PZpZQr
Mar 7, 2018 at 6:37 AM
