my a/c is working fine when i am putting in the heater it is not working
Dec 9, 2007 at 11:44 AM
CERTIFIED EXPERT
Hi there,
with engine warm up, check the temp of both heater hoses with the temp on high. If not hot to touch, you may have a blocked heater core or a faulty heater tap. If both hot the venting system flaps could be stuck closed.
mark (mhpautos)
Dec 9, 2007 at 4:10 PM
CERTIFIED EXPERT
The #1 reason a heater will not work is low on coolant, check out this video which should help.
