Heat is not blowing as warm as before replacing heater core
2000 DODGE DURANGO
240,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
ASHLEE07
I just changed my heater core, put new hoses on as well and my thermostat is new and working as well. But now the heat does not blow out as warm as before I had the heater core issue. Any advice or suggestions welcomed please help
Nov 26, 2018 at 6:05 AM
Good afternoon,
Did you get all the air out of the cooling system?
Try running the engine at 1200 rpm for five minutes with the cap off. Watch the coolant level and see if you get heat. If you do, it had air in the system.
If it does not then it may be the blend door, but doubtful if it worked before the repair.
https://www.2carpros.com/articles/car-heater-not-working
As the engine operates, any air trapped in cooling system gathers under the radiator cap. The next time the engine is operated, thermal expansion of coolant will push any trapped air past radiator cap into the coolant reserve/overflow tank. Here it escapes to the atmosphere into the tank. When the engine cools down the coolant, it will be drawn from the reserve overflow tank into the radiator to replace any removed air.
Nov 26, 2018 at 6:12 AM
ASHLEE07
Thanks for the fast reply. This is my father in law's vehicle I will give him your advise as soon as possible. Hopefully that is the issue.
Nov 26, 2018 at 6:19 AM
Sounds like a plan.
Keep us updated.
Always glad to help.
Nov 26, 2018 at 6:20 AM
