healer coil
WAYNE45
my spark plug blew out its stripped i was told to get a healer coil kit is there any other thing i can do bought a new spark plug and wont screw in is buying a healer coil the only way to fix it or is there some backyard mechanic repair i can do please help
May 15, 2013 at 2:19 AM
HMAC300
  • 48,601 POSTS
heli coil is the cheapest/easiest way to fix a blownout plug. Other wise yo need another head. Ithink they are aunder $50 at auto parts
May 15, 2013 at 2:23 AM
MADMIKE1735
  • 951 POSTS
heli-coil is only way to repair... however, you need to pull the sparkplug tube.... that is pressed into cylinder head, and is usually damaged on removal.... once you get it out, make sure you put gear grease on the helicoil tap to catch any metal shavings.... follow the instructions, you should be ok... just make sure to replace the tube if you damage it, and your going to need a valve cover gasket.... have the parts before you do the job so your prepared.
Sep 14, 2013 at 1:33 PM
