Yesterday I took car to shop, they performed a diagnostic and said the head gasket is blown
165,000 MILES • 4 CYL • AUTOMATIC
KAT625
It has as always idled rough but it started getting worse, even after having a tuneup done in February. Also six months or so ago it started leaking coolant. The problem was eventually found to be the radiator, also changed in February. Yesterday I took car to shop, they performed a diagnostic and said the head gasket is blown. The car is not worth the money they want to repair it. So my question is, how long can it run like this and can anything be done to prolong its life until I can replace it?
Thanks
May 12, 2019 at 8:45 AM
SCGRANTURISMO
  • 4,897 POSTS
If this is the case I would recommend that you get some Blue Devil Head Gasket Sealer and follow the directions on the bottle to a "T". You can find it at any auto parts store for around $50.00. Please let us know how everything turns out. this video will show you how
https://youtu.be/Xi41RFMP8Ow
Thanks,
Alex
2CarPros
Apr 30, 2021 at 2:16 AM
KAT625
Thanks, I appreciate the advice. I will try it.
  • 55,740 POSTS
