Head gasket
183,000 MILES
JJONES1234
We added Blue Devil head gasket sealer but then had water pump and replaced. Will the Blue Devil hurt the vehicle now that water pump has been replaced?
Jan 24, 2020 at 10:53 AM
SCGRANTURISMO
  • 4,897 POSTS
No, it shouldn't. Are you worried that adding the Blue Devil will harm the new water pump?
Thanks,
Alex
2CarPros
Jan 24, 2020 at 11:17 AM
JJONES1234
Yes and also if it will harm anything else in the cooling system or the engine??
Jan 24, 2020 at 11:21 AM
JJONES1234
What would happen if you put it in but turned out you didn't need it because it was a different problem?
Jan 24, 2020 at 8:02 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
It should just add to the gasket seals that were already there. I don't believe it would plug or gum anything up. Just to be sure keep an eye out on your vehicle's cooling system to see if it overheats.
Thanks,
Alex
2CarPros
Jan 25, 2020 at 2:11 AM
