Head bolt removal
200,000 MILES • 4.2L • V6
HEXXTER69
My head bolts are way torqued and i need to remove the heads. what is an effective trick to break the head bolts loose?
Aug 6, 2021 at 9:03 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
If you don't have access to pneumatic air impact tools you're going to have to use a lot of elbow grease. I would suggest using the end of a floor jack handle or some sort of metal pipe to slip over the end of the ratchet to create more leverage. The torque on these bolts are around 36 Lb-Ft. Hope this helps and let us know if you have any further questions on this issue. Thanks for using 2CarPros.
Aug 6, 2021 at 6:10 PM
