harmonic balanc
1988 DODGE LANCER
200,000 MILES • 2.5L • 4 CYL • FWD • AUTOMATIC
ALAN54
  • 19 POSTS
I need to replace the harmonic balancer no my old car. What I need to know is the balancer vehicle specific or engine specific?
I threw the crankshaft pulley and broke all the bolts holding it on , Then had someone else fix it for me should have done it myself. Now I have a lot of vibration when the car is accelerating. I hope that this is the problem,
May 15, 2016 at 8:22 AM
HMAC300
  • 48,601 POSTS
they are engine specific if it vibrates when just idling then revving up it may be the balancer otherwise it may be tires/axle shaft etc. so check those first. if you need to remove balancer remove bolts holding it in and it may just come out or you will need a puller that auto parts stores may rent.
May 15, 2016 at 8:32 AM
ALAN54
  • 19 POSTS
The vibration is there when it is idling and in park, but gets worse when I put it in gear. And even more so when I give it some gas. I can barrow a puller from AutoZone and have two self-service salvage yards in my area to get parts from. Will the year of the car make a difference or should I try to keep it in the years of 1986-89 or will one off any 2.5L engine work?
May 15, 2016 at 8:43 AM
HMAC300
  • 48,601 POSTS
Try to keep it in the same model years.
May 15, 2016 at 9:14 AM
