Hard start when car is hot?
69,000 MILES • 4 CYL • 2WD • AUTOMATIC
LINK15
The car starts when cold. If I drive it 7 miles, get out run into a store and come back it will not start unless I give it gas. It doesn't do it all the time. When it does start, the tachometer stops working and the A/C Blows hot. If I turn it right off and on again, all is working. I got a new battery, and nothing codes when diagnostic is done. Dealer can't fix it as they don't know how If nothing codes.
Aug 13, 2022 at 9:38 PM
  • 110,248 POSTS
The idea that the tachometer isn't working makes me think it could be related to a faulty crankshaft position sensor. When they begin to fail, heat adversely affects them. When they cool off, they work again. That would also explain the tachometer not working.
Holding the throttle to the floor is a technique that can clear a flooded engine. If there is no spark at first, this could happen. Do you ever notice gray smoke or a strong smell from the exhaust when it does finally start?
If I had the vehicle, the first thing I would check is for a faulty crankshaft position sensor. If that is good, then I would check fuel pressure drop-off to see if there is a fuel injector leaking.
Take a look through this link and see if you feel it mirrors what you experience. Also, note that a faulty crankshaft position sensor may or may not set a diagnostic trouble code.
If I had to guess based on your description, this is what I feel is the cause. However, look through this and let me know your thoughts.
Aug 14, 2022 at 2:46 PM
LINK15
Thanks so much. I am having the crankshaft position sensor changed as I believe that may be the issue. I smell nothing, nor no smoke. It only does it rarely and only when hot.
Aug 14, 2022 at 11:31 PM
  • 110,248 POSTS
You are very welcome and thank you for the update. The idea of it happening only when hot leads me to that sensor.
If possible, let me know how things turn out for you. Also, let me know if you have questions or if I can help in any way.
Aug 15, 2022 at 11:59 AM
