hard shift from first to second gear
1994 CHEVROLET 1500
275,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
SWEETIE1965
  • 180 POSTS
Do you think a hard shift from first to second gear could be u joints or a vacuum line (leak)? It only shifts hard from first to second. All other shifts are normal and smooth.
Sep 28, 2018 at 7:24 AM
  • 110,244 POSTS
Hi and thanks for using 2carpros.com
I have to be honest, I don't feel a vacuum leak or u-joint would cause a hard shift. Often times it is related to hydraulic pressure in the transmission or an electrical component such as a faulty shift solenoid. Especially since it only happens from first to second. First, make sure the fluid is clean and full. If you haven't serviced it in a long time, you may have a filter starting to plug lowering fluid pressure. That could cause a hard shift.
Here is a link that discusses different transmission problems. I thought I would add it just in case there was something there you may recognize as a symptom you are experiencing.
Next, I want you to check for trouble codes. Your truck has a OBD1 diagnostic system. Here is a link that shows how to find codes. Do this and let me know if there are codes.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
May 14, 2021 at 4:26 AM
SWEETIE1965
  • 180 POSTS
I have changed the filter and transmission fluid about two weeks ago. It is full. I had to add some after the truck was driven so the torque converter could get the proper amount of fluid it holds. I scanned the truck for codes. It has two trouble codes. One is 13 which is oxygen sensor the other is 43 which is knock sensor. No other codes. Where would the knock sensor be located on a 4.3 Chevrolet engine? Or is it the same as the map sensor?
SWEETIE1965
  • 180 POSTS
Would any of these codes cause a hard shift from first to second? It only shifts hard from first to second. All others are smooth like it should be.
  • 110,244 POSTS
Hi again.
The knock sensor is mounted on one of three locations. It will be on the engine block. I attached a picture of the three locations. Now, the knock sensor is designed to recognize engine detonation. Basically, if there is valve ping, it changes the ignition timing to prevent the ping. Honestly, I do not feel that has anything to do with the transmission. The same with the o2 sensor.
Since the fluid is clean and full, I have a feeling it either has to do with line pressure or the 1-2 shift solenoid is bad. Picture 2 indicates where it is located on a 4L60E Automatic trans.
_______________________
Here are the directions for checking line pressure on a 4L60E transmission, which I think you have.
Pictures 3 and 4 correlate with this test.
LINE PRESSURE CHECK
1. Prior to beginning line pressure check, check the following:
a. Transmission fluid level.
b. TV cable adjustment.
c. Outside manual linkage.
d. Engine tune.
2. Connect a tachometer to engine and install oil pressure gauge as shown.
3. When checking minimum TV line pressure, apply brakes, then take line pressure readings in gear range and engine RPM indicated in chart.
4. When checking full TV line pressure, tie or hold TV cable to its full extent of travel and apply brakes. Take line pressure readings in gear range and engine RPM indicated in chart.
___________________________________________________
If you have the 4L80E trans, here are the directions for testing line pressure. Please note the time limitation for the actual test listed in the directions. It requires a scanner and these ones for the OBD1 systems are getting harder to find. Picture 5 correlates with these directions.
LINE PRESSURE CHECK
WARNING:Brakes must be applied at all times during this test to prevent any unexpected vehicle motion. Total test running time should not exceed two minutes, or transmission damage could occur.
1. Connect Tech 1 scan tool or equivalent to vehicle ALDL connector.
2. Connect suitable oil pressure gauge to line pressure tap.
3. Start engine and ensure transmission is at normal operating temperature and fluid level is full.
4. Check for trouble codes and repair if necessary.
5. With gear selector in Park, access "Override Force Motor" test on the scan tool, then increase force motor current in 0.1 amp increments (allowing five seconds for pressure to stabilize) and note pressure reading. Compare results with pressure chart. Line pressure will pulse either high or low every 10 seconds to keep force motor plunger free. This is normal and will not harm transmission.
6. If pressure readings differ greatly from pressure chart or if pressure is not within 35 - 177 psi in drive, park or neutral ranges and 67 - 324 psi in reverse range, refer to "Troubleshooting."
The last picture I attached is the location of the 1-2 shift solenoid for the 4L80E transmission.
Because your truck is a 1/2 ton V6, I feel it has the smaller trans. However, I added info on both. There is one other thing I would like to add. Way back in the day, (1996) there was a technical service bulletin (TSB) that was related to replacement of the shift solenoids. If I recall, it dealt with a rough shift. However, I don't think it was only related to the 1-2 shift. I did a lot of digging and found the TSB. I thought I would add it in case you wanted to read through it. It was related to the 4L80E transmission, which I question you have. The last picture I attached correlates with this TSB.
A/T - Shift Solenoid Update
Vehicle Powertrain Management Transmission Control Systems Actuators and Solenoids - Transmission and Drivetrain Actuators and Solenoids - A/T Shift Solenoid Technical Service Bulletins A/T - Shift Solenoid Update
A/T - SHIFT SOLENOID UPDATE
File In Section: 7 Transmission
Bulletin No.: 37-71-48A
Date: November, 1996
INFORMATION
Subject:
Transmission Product Updates
(New Shift Solenoids)
Models:
1991-97 Chevrolet and GMC C/K, P, G Models
1991 Chevrolet and GMC R/V Models with HYDRA-MATIC 4L8O-E Transmission (RPO MT1)
This bulletin is being revised to update the part numbers and to include 1995-97 model years. Please discard Corporate Bulletin Number 377148 (Section 7 - Transmission).
Service Information
Starting August 14, 1996 (Julian date 226) all HYDRA-MATIC 4L80-E transmissions are being built with the new solenoid assemblies. The new solenoids are serviced for all 1991 through 1997 4L80-E applications.
Parts Information
Previous Part New Part Description 10478125 10478132 Valve assembly, 1-2 Shift Solenoid (Black) 10478126 10478133 Valve assembly, 2-3 Shift Solenoid (White)
I hope this is helpful. I realize it is a lot of information. I would have already replaced the 1-2 solenoid, but again, I cannot be 100% sure that is the issue. That is why I am trying to give as much information as I can.
Let me know if any of this helps and if you have other questions.
SWEETIE1965
  • 180 POSTS
I was driving my truck a few minutes ago. I heard a kinda loud knocking sound coming from underneath the truck. It eventually stopped. When I got home and parked the truck it did the same thing with the engine shut off. What can do this? The truck has only two codes. One is the oxygen sensor the other is the knock sensor
SWEETIE1965
  • 180 POSTS
The knocking sound is coming from under the dash on passenger side.
  • 110,244 POSTS
That sounds like an issue with the HVAC blend air door or mode door actuator. Look through this link and see if it correlates with what you are experiencing.
SWEETIE1965
  • 180 POSTS
The A/C was blowing cool air. I know the A/C needs to be charged. The blower motor was blowing on my way home from work today. After parking the truck I started it up and turned on A/C. The blower motor stopped working all together but I can hear a knocking sound coming from around where the blower motor is under the dash on passenger side. It knocks for a few minutes then stops. It even does this when I shut the engine off and at start. It does it for a short time then stops.
SWEETIE1965
  • 180 POSTS
It does not have anymore trouble codes. I scanned it again.
  • 110,244 POSTS
That sounds like a blend air or mode door actuator making noise. It could be, however, related to the blower motor. It may be bad.
SWEETIE1965
  • 180 POSTS
I guess I can unplug both. Would that stop the noise?
  • 110,244 POSTS
If you unplug the actuators, you will loose temperature control or air flow direction control. However, if it is the blend or mode door actuator, it should stop.
Let me know which you try and which makes a difference.
SWEETIE1965
  • 180 POSTS
I unplugged the fuse for the A/C unit all together. The blower motor stopped working so I just unplugged the fuse. It stopped the knocking sound under the dash.
  • 110,244 POSTS
Then it sounds like there is an issue with the blower motor. The fan could be hitting something or the motor itself may be bad. Here are the directions for removal and replacement. Just in case you want to dig into it. The attached picture correlates with these directions.
___________________
REMOVE OR DISCONNECT
1. Negative battery cable.
2. Instrument panel compartment.
3. Front screw from right door sill plate.
4. Right hinge pillar trim panel.
5. Electrical connectors at ECM, as necessary.
6. ECM and mounting bracket.
7. Electrical connectors from blower motor, as necessary.
8. Courtesy lamp (if equipped).
9. Bolt from right lower dash support.
10. Blower motor cover.
11. Blower motor cooling tube.
12. Blower motor flange screws.
13. Blower motor.
INSPECT
- Blower motor terminals for distortion. Clean corrosion from terminals or replace motor as necessary.
- Flange of the blower motor for damage or distortion that could cause a leak. Repair as necessary.
- Blower fan for damage or distortion.
INSTALL OR CONNECT
1. Blower motor.
3. Blower motor cooling tube.
4. Blower motor cover.
5. Bolt to right lower dash support.
6. Courtesy lamp (if equipped).
7. Electrical connectors to blower motor.
8. Mounting bracket and ECM.
9. Electrical connectors to ECM, as necessary.
10. Right hinge pillar trim panel.
11. Front screw into front door sill plate.
12. Instrument panel compartment.
13. Negative battery cable.
- Check circuit operation.
If you have other questions, let me know. Also, I am basing this on unplugging the blower motor itself has stopped the noise. If that is incorrect, let me know.
SWEETIE1965
  • 180 POSTS
I unplugged the fuse for the entire A/C system since the blower motor stopped working. It stopped the noise.
  • 110,244 POSTS
Chances are it is one of the actuators then.
SWEETIE1965
  • 180 POSTS
My truck is shifting hard only from first to second gear. I have changed the filter and transmission fluid. I tested the TPS and volts are good. What can do this? The truck is giving me two codes. One is for the oxygen sensor the other is the knock sensor. Can a knock sensor cause this problem?
  • 110,244 POSTS
Hi again.
The knock sensor is a component mounted on the engine block. Its purpose is to optimize engine performance via ignition timing. Honestly, that really has nothing to do with the transmission. I really feel it is one of the components I mentioned in an earlier post.
SWEETIE1965
  • 180 POSTS
My truck started to hesitate yesterday while driving. I tested the voltage with a multi meter. I checked the resistance in the sensor. It registers 9.0 ohms where the blue wire hooks up and 11.6 ohms where the grey wire hooks up. I have no one to help me so that is all I can come up with. Should it have more or less resistance or is this normal? It is still shifting hard from first to second gear.
  • 110,244 POSTS
Hi and welcome back.
Which sensor are you referring to?
SWEETIE1965
  • 180 POSTS
I tested and replaced the throttle position sensor. I scanned the truck again. The only code it is showing is the knock sensor. It is hesitating pretty bad. It just started doing that yesterday. It is still shifting hard. It started shifting hard when I put it in reverse and in drive. It shifts hard from first to second. All other gears are fine. Whatever is doing this just started.
  • 110,244 POSTS
Hi again:
Often times when the transmission slams into drive or reverse, it is caused by either bad motor mounts or trans mounts. Have you checked them?
Since you still have the same code for the knock sensor, you may want to replace it to see if the changes the timing enough to eliminate the hesitation.
SWEETIE1965
  • 180 POSTS
My truck was shifting hard from first to second gear. I added some type of fluid to the transmission about a week ago. I was driving the truck last night, I noticed the hard shifting stopped. Should I change the fluid and filter again or leave good enough alone?
  • 110,244 POSTS
I would leave well enough alone. The friction modifiers in the additives are there to help prevent components from hanging up and to work smoother. Do not remove them.
SWEETIE1965
  • 180 POSTS
Okay. Thanks for your advice.
  • 110,244 POSTS
No problem. Let me know if you have other questions or need additional help.
SWEETIE1965
  • 180 POSTS
I changed the fuel pump and filter the other day. Now the fuel gauge is constantly reading full. I pulled it back out to test it. It seems to be working fine but the gauge is not working. Before I changed the pump the gauge read half tank of gas but I actually ran out of gas leaving me stranded.
  • 110,244 POSTS
Welcome back.
Either there is a problem with the sender or the wiring. I attached a diagnostic chart for you to follow. It will indicate if the problem is the sender or in the wiring. Take a look through it and let me know what you find.
SWEETIE1965
  • 180 POSTS
The truck was leaking coolant from the heater core. I changed it out. Now there is no lights come on on the control panel for A/C and heater. Blower motor stopped working as well. I do not want to replace more than I have to.
  • 110,244 POSTS
Have you checked the basics, fuses, connectors...? I have to be honest. I'm starting to get confused. Did you find the problem with the fuel gauge?
SWEETIE1965
  • 180 POSTS
Yes I found the problem with the fuel gauge.
SWEETIE1965
  • 180 POSTS
I checked the connections. One has constant power. Others have none. After I checked wire connections, the fuse blew two different times. I have fuses for it. I do not want to keep putting in fuses if they are going to just blow. I know there has to be a short somewhere. A hot wire is grounding to blow fuse. How do I find out where it is?
  • 110,244 POSTS
If you need to find a short, you have to start tracing wires. Since you just replaced the heater core, my guess is that you have pinched a power wire under the dash which is causing the fuses to blow. Start by retracing your steps when the core was replaced. Check all around the heater core box under the dash to see if anything is pinched. Also, remove connectors to make sure none of the pins got bent and are crossed.
Let me know what you find.
SWEETIE1965
  • 180 POSTS
I found the problem with the A/C. A bare hot wire near the compressor was grounding. I repaired it and gas gauge is also repaired. I changed filter and transmission fluid again. It still shifts a little hard but not like it was. It shifts hard from first to second at times. Not every time I start going in it. So I will leave good enough alone for now.
  • 110,244 POSTS
That is good to hear. Let us know if you have questions in the future.
SWEETIE1965
  • 180 POSTS
As I asked about left turn signal light blinking fast, I was checking all the lights to assure they was all working when I noticed one in the front is burnt. Not the signal light bulb though. I believe it is the marker light or the running light. Would that cause the signal light to blink fast like it is? And one of the actuators clicks but it does not affect the direction the air is coming out of. Where ever it is set to come out of it comes out. A/C and heater both work. The A/C just needs to be charged.
  • 110,244 POSTS
Hi:
A marker light will not cause the signal to flash faster. As far as the clicking, the actuators have a small plastic gear inside. The gears have a tendency of stripping and then clicking. Eventually, it will fail and need replaced.
CMPRGUY65
  • 6 POSTS
I found the problem with the heater. A shorted wire near the A/C compressor was touching which caused the fuse to keep blowing. I have another problem. I changed the heater core. Everything was fine until yesterday. I checked the anti freeze after returning from work yesterday. The coolant was almost empty. I flushed the cooling system out with Prestone coolant flush upon changing the heater core. I added Prestone coolant to the system until filled. There is no visible leaks, no coolant mixing with the oil. I am stumped. I cannot find where the leak is. I have changed everything I can and it is still leaking. Even the radiator cap. Like I said there is no visible leaks anywhere. Where is the coolant going? I know it has to be leaking but I just cannot find it. The heater core is not leaking.
  • 110,244 POSTS
Hi and welcome back:
I hate to ask, but I need you to start a new post. I was requested to keep each thread limited to one problem. Copy and paste the coolant issue to a new link and I will keep my eyes open for it.
I am sorry for the request, but I want to respect the owner's request. I hope it is not too much of an inconvenience.
CMPRGUY65
  • 6 POSTS
Okay, I will.
