Grinding noise when going over bumps
  • 109,885 POSTS
The idea there is an issue with the parking brake makes me question if there is an issue behind the rear brake rotor (parking brake assembly). Have you had things apart? It's possible a retainer or spring may have come loose or off.
Let me know if you have already checked.
Thursday, April 16th, 2020 AT 6:35 PM
DCANNON1390
  • 40 POSTS
I have not checked, but when I turn the parking brake on the light does come on.
Thursday, April 16th, 2020 AT 9:55 PM
  • 109,885 POSTS
I have to be honest. It may be a good idea to check. I would safely lift and support the rear wheel. Spin the wheels and see if anything sounds odd. I would then pull the wheels and check the brakes.
Friday, April 17th, 2020 AT 4:38 PM
DCANNON1390
  • 40 POSTS
Okay.
Saturday, April 18th, 2020 AT 12:25 AM
DCANNON1390
  • 40 POSTS
Nothing sounds funny I did a tire rotation myself and checked the rear wheels and it didn't make any funny noise. Do you think it could be the CV boot or could it be something else?
Tuesday, April 28th, 2020 AT 8:34 PM
  • 109,885 POSTS
Is it loud enough to record on your phone? If possible record it and upload it for me to hear. The idea that it stops when you turn hard right, it sounds like a bearing on the right side of the vehicle, likely the right axle bearing. You are certain it isn't something crazy like a bent backing plate behind the brake rotor rubbing, correct?
Wednesday, April 29th, 2020 AT 7:59 PM
DCANNON1390
  • 40 POSTS
Turns out it was the e brake. Removed it and it stopped.
Sunday, June 21st, 2020 AT 12:11 PM
  • 109,885 POSTS
Thanks for letting me know. I was wondering how this turned out for you. I'm glad to hear it is repaired. Feel free to come back anytime in the future if you have questions.
Sunday, June 21st, 2020 AT 8:58 PM
DCANNON1390
  • 40 POSTS
Will do.
Sunday, June 21st, 2020 AT 9:01 PM
