Grinding noise
160,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
GBENNER
When applying the brakes there is a grinding sound that sounds like metal on metal. When I changed front brake pads I noticed that the rotors were loose and came right off. I tried to wiggle the hub to see if it was wheel bearings but I had no play.
Mar 12, 2018 at 3:55 AM
  • 55,658 POSTS
Is the grinding sounds coming from the front or rear? I quick video and upload it in your reply would help us. If the grinding is not the brake pads it will be the front hub or the e brake shoes. Here are two guides to help you see what you are in for when doing the job:
https://www.2carpros.com/articles/parking-brake-shoe-replacement
and
https://www.2carpros.com/articles/bearing-hub-replacement
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Mar 13, 2018 at 5:10 AM
