grind/whine noise coming from clutch or tranny on take off... sound goes away once im going and gears shift perfectly besides quick thud of gear engag
2004 BMW 325I
130,000 MILES • 2.5L • V6 • RWD • MANUAL
ARBERY1992
my clutch went out about two weeks ago... tranny was fine before.. got car back from mechanic.. when its in neutral idol.. i hear a small ticking noise. when i put in gear and depress clutch it grinds/whines until i get to a good rolling speed. what could this be??? flex plate??? throwout bearing??? idk
Oct 12, 2015 at 6:55 PM
WRENCHTECH
  • 20,761 POSTS
Could be a problem with the clutch parts or installation. Could be the hydraulics still have air in the system. Either way I would just bring it right back to the shop that did it.
Oct 12, 2015 at 7:16 PM
ARBERY1992
It took them 2 weeks to give me back my car and they admitted that they didn't know what they were doing and had to contact bmw several times.. over a clutch installation?? I'm pretty handy when it comes to cars and can fix most problems just need to know from a professional opinion.. is it most likely a throw out bearing?
Oct 13, 2015 at 6:27 AM
WRENCHTECH
  • 20,761 POSTS
The solution will be found through examination. The transmission may have to come out again so they should be responsible.
Oct 13, 2015 at 6:29 AM
