1999 GMC Yukon P1345 Code
STRUXGL
  • 11 POSTS
My vehicle is a 1999 GMC Yukon with a 5.7 engine and 120,000.
The "servie engine soon" light came on after I replaced the intake manifold gasket because of a anti freeze leak.
My code reader says the code is P1345 which in my book says the is a camshaft to crankshaft corrleation fault.
Does this mean that I did not get the distributor back in exactly the same posistion as it was?
If so, how do I fix the problem?
Jan 14, 2007 at 9:21 AM
BACKYARDMECHANIC
  • 337 POSTS
You may have damaged or not installed the harness right for the camshaft sensor after repairing the intake manifold gasket. Do a thorough inspections of the harness and check connection points. As far as the vacuum gauge goes I like to connect it to the hose that goes to the pcv valve. It is easy to remove and get at. It also has a contstant vacuum and what is required to operate the gauge. A good vacuum reading will be 17-22 hg with a steady needle. BTY the needle reaction is more important then the actual reading. The gauge usually comes with a chart describing the different readings and what they mean. This is a good chart to have to refer to.
Good luck :D
Jan 17, 2007 at 11:15 PM
Suggested Repair
After the intake manifold gasket repair, thoroughly inspect the camshaft sensor wiring harness and connection points for damage or a poor install that could set P1345.
Conversation Summary
A 1999 GMC Yukon 5.7 owner reported a service engine soon light and code P1345 (camshaft-to-crankshaft correlation) after replacing the intake manifold gasket, and asked whether the distributor was reinstalled out of position. The reply advised checking that the camshaft sensor harness was not damaged and that connections are secure, and also described a general vacuum-gauge check at the PCV hose.
