GMC Yukon Reverse Grinds
MELIOS1000
sometimes my yukon will not go into reverse unless i really step on the gas and then it grinds other times it is fine could the emergency brake just be stuck or something
Jan 27, 2007 at 12:54 AM
CHEVY22
  • 1,375 POSTS
you should have the 4l60e depending on what engine is in the vehcile , if so , there, was a problem with the reverse reaction sungear shell stripping ,there is an updated part but you almost have to do an overhaul to get the job done
jim
Feb 15, 2007 at 9:56 PM
Suggested Repair
Have the 4L60E transmission inspected for a stripped reverse reaction sun gear shell. An updated part is available, but the repair typically requires a transmission overhaul.
Conversation Summary
The owner of a GMC Yukon reports that reverse sometimes will not engage unless the accelerator is pressed hard, after which it grinds, while other times it works normally. The expert says the vehicle likely has a 4L60E and that the reverse reaction sun gear shell may be stripping; an updated part exists, but replacing it generally requires an overhaul.
