REALLY Stuck pitman arm
PULSTI
  • 28 POSTS
I have a 94 yukon and am having trouble with removing the pitman arm.
I removed the relay rod and idler arm and got a pitman arm puller but on my truck the frame is 3 inches directly under the steering box where the pitman arm connects leaving me with no space to fit in the puller, i dont want to use a pickle fork because it might ruin the gear on the steering box plus the forks are not even wide enough. This is my only car and I need it ready for the winter. Any advice would help me please.
PS. I tried to put it all back together to drive to the shop and have them do it but now the ball is spinning on the pitman arm when I try to put the nut back on. I'm s*@! out of luck right now!!
Nov 6, 2007 at 1:47 PM
ROOSTER_MAN45
  • 11 POSTS
You have to remove the steering gear from the truck,or lock the steering wheel ,remove the mounting bolts of the steering gear.Turn it sideways and get a pitman arm puller and a good impact to remove the pitman arm itself. To get it loose from the drag link , pickle fork or strike the draglink with a 3LB hammer next to where the pitman arm joins it , the shock will break it loose.
Sep 23, 2010 at 12:31 AM
