Does not steer unless truck is moving
140 MILES • 0.5L • V8 • 4WD • AUTOMATIC
BIG SPAZMAN
Unless truck is in motion,backwards or forwards, you cannot steer at all.
Is the problem the power steering pump, or the rack and pinion gear box? how can I tell the difference?
I do not wish to pull the wrong parts at PickNpull again.
It is cold out now!
Nov 16, 2016 at 8:43 PM
HMAC300
  • 48,601 POSTS
it may be the belt and tensioner as replacement should be done at 60,000 miles. But have pump checked for pressure and make sure it is full.
Nov 16, 2016 at 10:51 PM
BIG SPAZMAN
Thank you
Nov 20, 2016 at 1:49 AM
  • 55,688 POSTS
Hey Big,
It sounds like the steering pump has gone out. I had a problem like this with a Tahoe in the shop.
Here are some links that will help you see what you are in for.
https://youtu.be/EXDysSOs07g
Please let us know what you find so it will help others.
Best, Ken
Nov 20, 2016 at 9:07 AM
