1996 GMC Suburban Lights Flicker
COWBOYSANDSKYNYRD
GMC Suburban 96 / 140,000 miles With the lights turned on and the engine idling, the interior lights and headlights will flicker/jump. I have not added any aftermarket equipment. The battery needle will jump with the flicker/jump. My alternator and battery is fairly new (both replaced within 6 months). The engine runs smooth, no power window problems or any other electrical problems. Any help?
Jun 24, 2006 at 4:29 PM
BURRBRIAN
  • 158 POSTS
Kinda sounds like you have a belt slipping a little. Maybe the tension on it is not strong enough or it's wore down a little slick. This could account for your rise and fall of power output. Something to check on, anyway. Good luck 8)
Jun 26, 2006 at 10:33 AM
Suggested Repair
Inspect the drive belt for slipping, a slick worn surface, or insufficient tension, which can cause fluctuating alternator output and flickering lights.
Conversation Summary
The owner of a 1996 GMC Suburban reports that the interior lights and headlights flicker at idle with the lights on, and the battery gauge jumps with the flicker. The alternator and battery were replaced within six months, and there are no other electrical problems. The expert suggests a slipping or worn drive belt or weak belt tension as a possible cause of the fluctuating power output.
