how to replace power brake booster
BUDMOORE
98 chevy Suburban 120000 miles How do you get the booster off from the brake pedal?
May 20, 2006 at 6:11 AM
LOSONE
  • 1,616 POSTS
First take off the nuts securing it. The extended booster arm has a small clip holding it to the brake pedal assembly. Remove it and pry is off with a screw driver. Good luck
Mar 11, 2021 at 5:33 AM
