1984 Chevrolet Suburban Brake Rotors
CHILE23
i got a 1984 chevy suburban 4x4 350 1/2 ton and in my manual it doesnt really explain on how to take off the brake rotors and it seems more difficult due to the vehicle being 4x4 if you got any tips or any help please send it thanks chile23
Nov 4, 2007 at 6:17 AM
BLACKOP555
  • 10,386 POSTS
first thing is first jack up car and support with jack stands. then take off the wheel. this video will help
https://youtu.be/CQTfR7qiUMA
next disassemble the braking system, take off the brake pads and mark then and then take off the calipers. this should leave the rotor left, of course the rotor will probably be jammed on there due to all the wonderful stuff on the road during the winter and rust.
so if you have a torch heating it up could help with prying it off. be careful not to ruin anything.
Mar 15, 2021 at 3:36 AM
Suggested Repair
Safely jack and support the Suburban, remove the wheel, mark and remove the brake pads, then remove the caliper. If the rotor is rusted in place, carefully heat it and pry it off without damaging nearby parts.
Conversation Summary
The owner of a 1984 Chevrolet Suburban 4x4 asked how to remove the brake rotors because the manual was unclear and the four-wheel-drive setup seemed to complicate the job. The expert advised supporting the vehicle on jack stands, removing the wheel, marking and removing the pads, and removing the caliper. If rust holds the rotor, careful heating and prying may help free it.
