1998 Chevy Suburban Brake Booster Pedal Fix
BUDMOORE
98 chevy Suburban 120000 miles How do you get the booster off from the brake pedal?
May 20, 2006 at 6:11 AM
LOSONE
  • 1,616 POSTS
First take off the nuts securing it. The extended booster arm has a small clip holding it to the brake pedal assembly. Remove it and pry is off with a screw driver. Good luck
Mar 11, 2021 at 5:33 AM
Suggested Repair
Remove the nuts securing the power brake booster. Then remove the small clip that holds the extended booster arm to the brake pedal assembly and pry the arm off with a screwdriver.
Conversation Summary
The owner of a 1998 Chevy Suburban asked how to disconnect the power brake booster from the brake pedal. The expert advised removing the securing nuts, then removing the small clip on the booster arm and prying the arm off the pedal assembly with a screwdriver.
